Going off grid.
So it turns out the guy at the dealership didn't know what he was talking about, the trailer is also 24 volt. Everywhere I look 24 volt batteries are ridiculously expensive. Can anybody recommend a good vendor for these?
Lets go back to your first post. You say you have an Econoline E350, so do I but mine is 30 years old. How do you come to have a 24v system in it? And I have never seen a 24v production camper. It seems you are talking about a solar system in your 350? In your trailer?
The E 350 is a bus conversion with a wheelchair lift, hence the 24 volt. The trailer I have no idea why but it came with a 24 volt battery. It's a 2023 Coleman light. I'm planning to do solar. I've ordered 400 watt panels for both along with charge controllers. The trailer came with a 24v 88 AH battery. That should be good for the bus, but I'm looking for 300 AH for the trailer
Almost nothing else in that bus is 24 v. So I don't think the main power is 24v. If the wheel chair lift uses 24v by pulling from 2 batteries in series that does not mean everything else is running on it. Check voltage at any bulb in the lighting system. Check it at the hitch plug. I don't think Coleman has ever made a 24 volt camper. They make campers exclusively for Camping World.
Please show me a picture of this battery.
The bus only has one battery, a 24 volt. Here's the battery that came with the trailer
Typically two 12vdc batteries are connected in series, for 24volts. If lithium is your desire be sure the BMS will work with 24volts. If you choose lead, may I suggest Northstar Blue+ batteries. I sourced mine from Northern Arizona Wind and Solar. They too, are expensive, but the cycle life of its carbon lead technology leaves lithium in the dust! They come with bus bars to connect them in series.
The math told me at time of purchase put them inline with QUALITY AGM BATTERIES. Oops had the cap button on, to lazy to fix it!!! Now I was in the market for a new 12v battery and went shopping, only to consider other options, the prices have gone through the roof!!! So telling you what technology holds the best deal in the current market, only the powers pushing technology can tell!
That is a group size designation.......It is not 24 volts DC. Put a meter on it.
IF you replace and can fit it in put a 27 in.
The dimensions for the Northstar Blue can be found here
I use the blue+ and was willing to accommodate the form factor. I use the 190s and they are setup as 24 volt system. My system consists of two batteries making 190 amps of storage.
Household fridge and freezer are what I limit my usage to on cloudy days in AZ and run the charger when needed. In the last year I had to drain the old gas before running it because 6 or more months go by between it's need.
My solar is considerably larger than what you plan, and that makes a big difference, however you should be fine with 800 watts.
The big difference would be I can use electric appliances during the day without the batteries taking a hit! Actually my controllers go into bulk charge mode when I use high use loads. So at the end of the day my batteries have a higher state of charge!!!
If you are planning to increase your bank, then plan as well, for different form factor batteries. Also look at the PDFs at the link above.
My daughter who lives off grid in Florida, was using these batteries for 4 years when she told me about them 3 years ago. She still has no problems with them, and I wouldn't replace them with anything else.
Well, there ya go. I still don't think Coleman did that, but maybe. And to run the E350 on 24v they must have installed something to reduce the voltage to all the components in the truck.
And to charge it would take some gymnastics with the alternator.
Or not!
So you think the engine computers and the bulbs and all the workings are fine at 24v? Hmmm. Maybe I need to study it a bit. Not sure why other then to satisfy my own questions. I don't think I will be building anything as long as I can get a generator. Noticed some Cummins 24v threads while searching.....
