Thanks for the input TJ.Welcome to RVF, @Hotdoggin; glad you found your way here.
After more than 50 years of RVing, I have never run across a propane heater to use indoors that I felt was safe. There are a number of catalytic propane heaters, but all of them consume oxygen and none (that I've found) have a thermostat to regulate heat.
This is why we have a big generator in our coach for when the power goes out.
Thanks Kevin. I need to look these up. Wondering where you get them?People that follow their own path take chances. Or so I have been told. I have used Olympic wave 8 without any problem. well the problem is there is no thermostat. I use a 3 brick heater, no they are not vented but following the owners manual are safe enough. I seldom heat at night, but then I travel for temperature. Have used these heaters, now 20 years and counting. we are still kicking and well.
Ok. Found them. Turns out i am quite familiar. These are high quality units. So much so that a trucking company used these in the trailers for freeze control. Low consumption and easily kept the semi trailers avove 32deg.Thanks Kevin. I need to look these up. Wondering where you get them?
