Heater question
jklune
The propane heater in my 5th wheel will not ignite above 4000 ft elevation. I've had 4 trailers prior to this one and never had this problem even at 9000 ft. Has anyone run into this problem and how did you fix it. Winnebago says this is normal and won't repair the problem.
Sounds like a load of horse puckey to me.. I've camped at sea level up to 9000' and never had a problem with a propane furnace.
That said, Winnebago isn't likely the right place to start. AFAIK the furnace warranty would be through the furnace manufacture, I'd contact them.
