- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
I just helped a fellow camper a few days ago. He had similar issues as yours. Turned out the converter/charger breaker had tripped. This is the 120v breaker in the panel. Looking at the breaker, it did not show as being tripped, but when he went to cycle it, there was no resistance turning it off, and then it had resistance going back on. The battery immediatly showed 13.5v, indicating it was taking a charge.
Check the converter / charger breaker, then check the output voltage of the charging circuit. It should exceed 13.0 volts.
