Question Holiday Rambler Vacationer
Had hot water, all a sudden no hot water coming in kitchen or bathroom, but had cold water.
Do you have water coming out of the hot side at all? Or just not hot water?
My Holiday Rambler has a bad anti drain back valve so intermittently everything works just fine and then for no apparent reason I get no water at all out of the hot side. The spring inside the valve has failed and the plunger is just flopping back and forth. Search YouTube and you'll see videos on how to replace this valve. It's not a Holiday Rambler problem either, it happens to all make and models. Good luck!
Check your outside shower, if that is on sometime the Hot Water tank or tankless heater will not kick in, just make sure its off and turn on the Hot Water, see if that works first, if you have a tankless you could have a Bee or something that got into the intake line, take a tooth pick and move it around and see if something flies out
