Holiday rambler
diana87
My tank level screen will not turn on. I have tried everything, check fuses in the 3 boxes (are there more?), breakers, disconnect batteries switch, connected to shore power, using batteries only. Nothing turn it on, therefore I can not turn on the hot water!
Any suggestion?
I have a 2016 HR Vacationer 37BH
Welcome to RVforums from Ely, Iowa. I am not familiar with your RV however if you have an inverter/converter there are (at least on Mine) circuit breakers on the face of it that will occasionally trip. May also have to remove the panel and check and see if a connector is loose. Let us know what you find out. The info will be helpful to someone else down the road. Safe Travels and Enjoy RVforums.
