Hot water heater leak
2017puma
Puma
32FBIS
32ft
I’m having an issue with my hot water heater leaking on the INSIDE of my camper I have a 2017 puma 32fbis. In side my bunkhouse which is located in front of trailer I have two bunks on the left and underneath the lower bunk is where my hot water heater is located along with some hoses and other things. Underneath the bottom of my hot water heater right below where the cold water line connects is leaking water more like running water. Anyone had this happen or know what may be the cause?
Can you see the fitting? Some manufacturers use plastic fitting that can break. Wiggle it or try to tighten it to get a better idea. Also check the hose connection to see if it is loose.
