Question House Batteries
NWIP
No Where In Particular
Dutch Star 4369
43’ 9”
Spartan K2
Cummins ISL9
2023 GMC Sierra
Time for house batteries and looking at Lifeline GPL-4CT and looking for input from those that have experience with the brand
No I’m not interested in lithium and yes I know cost of batteries is comparable to lithium batteries without the other accessories
Thanks
The people I know with lifeline batteries have nothing but good to say about them.
I personally use Northstar blues, I also have nothing but positive to say about them.
Thanks
Check out VMax, I bought 4 big 400ah AGM's from them and am very happy.........Fast free shipping.
VMAXTANKS Super rating's also!
From 8 GC2 Batteries to 4 V Max Tanks AGM..........GLAD THE WET CELLS ARE GONE!
I replaced my original interstate batteries with V Max and the batteries as well as the company have been awesome. I should note that I switched out the interstate batteries three years ago. These batteries had a build date of 2006 my rig is a 2007 pretty good life.
The V-Max batteries are sometimes known as the higher energy battery. More active material and higher electrolyte strength. They operate at a slightly higher voltage through the discharge curve which makes them a much better choice for inverter support and other RV applications. As a part of that, to get the most out of them they need to get charged at slightly higher voltages.
BCI Group Size: 4D
Reserve Capacity (25A to 10.5V): 460 Minutes
20hr Capacity: 200Ah
Cold Cranking Amps: 1120 A
Marine Cranking Amps (MCA) 1400 A
Charging Current: 15A-60A
Charging Voltage: 14.4-14.9V
Float Voltage: 13.5V-13.8V
Cycle Life: 1,600 Cycles at 25% Depth of Discharge (DOD); 900 Cycles at 50% DOD; 550 Cycles at 80% DOD
Design Life: 8-10 Years in Float Service
This is really in line with Lithium except Lithium never needs to go over 14. 6 volts. Note the max charging rate is ~3.33 hours, 4 hour max rate more typical for AGM and 6 to 8 hour better for longer life.
Installed mine in Dec 2020…no issues. I will replace them this December. The literature they provide give you excellent charge and discharge graphs…making it easier to calculate the aH capacity remaining on aging batteries. I have literally done nothing to them since I installed them. Unlike the Interstate FLA they replaced. Those needed water refills and terminal cleaning often. What a mess.
But like any batteries…don’t let them deep discharge, especially in freezing weather.
Thanks
Bill, I purchased these Lifelines a couple of years ago and have no complaints. I’ll be happy to share my purchase details with a private message.
Thanks for input planning on replacing late September when in GA, that way my son can do the heavy lifting 😜
