Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
When I started out RVing 2-1/2 years ago the question with no real answer was when to change the water filters. I think the general rule for a house water filter was a year. Then as I traveled and had autofill timeouts I learned the house water filter can contribute to the problem and that may be a good rule as to when to change the water filter. I've learned a lot over the past 2-1/2 years and I can tell you depending on autofill timeouts is NOT a good indicator. If you run your fresh tank near dry simply filling up the tank on autofill will likely trigger an autofill timeout (at least on my coach) so that theory is out.
What do I do now? Quarterly. Filters are related to your health, CG water supply we all know is something we'd rather not think about. Filters are cheap, I get them from Amazon and just like the AC vent filters in my S&B the beginning of each quarter the filters are changed regardless of what they look like when opening the house water filter container. One of my filters is a carbon filter and I do believe that's a 6 month rotation, I'm not sure on that one yet but I recently went to a dual filter setup so I have to figure that one out.
How often are you changing your water filters and do you do it on a schedule or some other indicator of needing a change out?
