HWH Active Air issue - left front cycling up and down while air leveled
Thanks for the info. If I read correctly you did order a new solenoid? Or you are waiting for Joe’s email?
Crawled under the coach this morning and found my manifold. It is located in front of the left front wheel outside of the main frame member. Not a perfect spot but at least I can access it. I’ll wait until you hear from Joe before ordering anything and I’ll give him a call.
I ordered a part from Joe. I’m not sure what it is exactly. Give him a call.
The other side of those air hoses are solenoids. I bet that’s the part coming. Let me know what you learn.
Sure wish that manifold was in a more accessible spot. Story of my life so it would seem. 😁 I did call Joe and am on the callback list.
Mine is not better. Started up to go to storage and front end was down. Immediately raised to ride height on start. Parked for 2 hours.
agreed with my theory that the valve that opens to push air in the airbag for air leveling is not closing or sealing so it's leaking back out within the system as both of us can't find leaks.
Reading back thru the thread, I reread this and had a question. Are you sure it’s the valve that adds air to the system that Joe is talking about? Wouldn’t it be the exhaust valve that is leaking as air is leaking out not in. Or are we just talking semantics here?
And, the mufflers are in the exhaust line obviously.
All I can say is I described the situation and he seemed to know the part to replace. I got an email from him which I haven't had a chance to read yet, just getting settled back home. After I parked at storage I opened the front to listen, didn't hear anything, didn't see anything happen, went in to do something and came out and left front was all the way down. I still didn't hear anything. I came in and put the key to accessory and checked the PSI's right away, left front was 21 psi, right front was around 70 psi. So I know it's the one area (left front). But if it was an exhaust leak I think I'd hear something, my hunch is the fill line has a valve that's not closing so there is no leak, it's all in the contained system (air lines) and just going back to tank 2 per se and not actually venting out of the system. I didn't try to repeat it, had to leave but it seems whatever the time interval is that AA checks for its pressures after engine stop such as air level update intervals, that's when it opened and lost the air to LF. In other words, the line is not maintaining pressure, but doesn't mean it's actually venting/leaking.
The front side of the manifold I can access, the back side is going to be a problem if I have to get up in there.
Good afternoon Neal
I have attached to this email a drawing if you will of an Active Air
front manifold. I do not have one that is exactly like yours, yours will
have a module on the side of it and this one doesn't.
What I have done is mark which one is going to be the left lower valve
that will need to be replaced. What you will want to do is drop all the
air in the coach so all the bags are flat. Go underneath to the manifold
and locate the left lower valve and unplug it. Then once it is unplugged
use channel locks and simply unscrew it out of the block. Then screw the
new one in and then plug it back in and you should be good to go.
Of course before you drop the air in the coach you may want to drive the
front up on blocks (do not put the jacks down and crawl under it) so you
have room to get under the coach and work on this.
Hopefully this all makes sense?
Thanks
Joe
Hence the muffler that would stop a noise leak. I give…..I know nooothing. God I wish HWH were in Oregon or Nevada!
Welcome home. Order a large Hawaiian pizza and enjoy your evening.
Aha! That is the exhaust (lower) solenoid. Wouldn’t you know that the one for the right side is in the least accessible spot on my coach.
Hopefully Joe will get back to me soon. Sorry for all the posts but you have been a great help pushing me to fix this contraption.
Maybe so and I guess I should remove it and test. But I’m determined to find and fix it. Next time I go to the coach I’ll remove the muffler and test but I don’t know when that will be. I’m not in a rush and not leaving on next trip for a few months. If needed I’ll go to HWH as I’m headed that way. When mine gets fixed we’ll know what to do with yours but I think we’re at least pointed in the right direction right now. It’s within that manifold contraption I believe.
Not easy on mine either but I’ll get it done.
Yea, vetting this together helps. We’re going to get it. And learn a lot along the way.
I wonder if taking the exhaust off and lubricating it would do anything? Shoot some WD40 in there?
My guess is you would be better off removing the solenoid and checking its seals but a bit of lube in the exhaust couldn’t hurt if you can direct it to the valve.
