Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I asked Joe about using WD40 and this was his reply:
I told him you reached out to him Jerry and that you have the same problem. Not sure if you two connected yet.
I replied to Joe asking if any thread sealant is needed with the valve replacement and if so what do we use.
Good morning Neal
You can certainly try it but I do not think it is gummed up. I suspect something got between the needle and seat and it is either still there or the seat is damaged and it will never seal no matter what you do.
If you want to try to get rid of it start the coach and build it up on air, then go to manual leveling and raise the front bags as far as they will go then lower the front bags all the way down. Do that a couple of times and see if it works. If it does great you are home free, if not you have a valve coming you will just need to replace it. Personally I think you will end up having to replace it, but you have nothing to loose by doing the raising and lowering except a little bit of time.
Looking at the pictures it looks to me like the manifold is not to bad to get to so changing the valve will be easy.
Thanks
Joe
