HWH solenoid replacement, which one?
slahaie
Good afternoon, i have a 2006 Itasca Ellipse 40FD with my passenger side living room slider extended and wont retact. I am sure the solenoid needs to be replaced, but not sure which one. Is there a document somewhere that will tell me. I have 4 slides and of course the leveling system all on one manifold. thx...
Ok, i seem to have identified solenoid #4, by simply unplugging each of the other retract solenoids and test each slider operation. There is no room to grab this thing to remove it, and found there is a tool, old and new, that attaches to the cap. Ordered it and hopefully will try again this weekend. It seems the best access is climbing under the MH and just aft of the unit there is a small space I can somewhat sit up and get at this this. We'll see once i receive this tool. Will let you know. although it seems nobody is interested in this post. shrug...
You are waiting for someone that has had your problem of knowledge of it. That can take some time. The cost of that solenoid may shock you....and I would be testing the wires that go to it first. And then the switch......Is this an HWH system or an RVA?
Swap the plug going to the solenoid that you suspect is bad to a good solenoid. Then try activating the button again. If the slide works then you know it’s a bad solenoid
