DennisT
RVF Expert
- Dec 1, 2022
- Superstar 4061
- FCCC
- Cummins 360
- 2022 Jeep Cherokee TrailHawk
- Yes
Is this measuring inverter output or pedestal line voltage? I believe it's inverter.Installed a small plug in volt meter in a rarely use 110v outlet just to keep an eye on pedestal power. This was a meter from Hughes. interesting to see the daily variations.
Just a friendly note. Make sure if you off grid running on batteries only that you remove this device or turn it off as it will drain battery over time. When I redid my coach electrical I added a hard wired dual 12 volt monitor . This allows me to monitor the chassis and house battery lever. I added the switch for two purposes; one to save batteries and secondly because the LED display was reported to be so bright it would illuminate the coach at night. It truly is that bright. Small but mighty. I love having this available to know where my battery status at times. Happy Trails to You!Installed a small plug in volt meter in a rarely use 110v outlet just to keep an eye on pedestal power. This was a meter from Hughes. interesting to see the daily variations.
