Installing a diesel heater in your RV is a good option
HarperWking
My expericnce
One thing that completely changed my winter RV trips is the diesel heater. I used to struggle sleeping in the cold, but ever since I started using it, I finally get a warm, restful night. It heats up pretty fast—especially when it’s freezing outside. Within 10 minutes, the RV gets nice and warm. Plus, it barely uses any fuel, even if it runs all night. What I really like is that it doesn’t rely on external power. Whether I’m in a campground or out in the middle of nowhere, it just works. That gives me peace of mind. It’s also quieter than I expected. I barely notice it at night. The controls are super simple too—just set the temp and press a button. It hardly takes up any space. Once it’s installed, you pretty much forget it’s even there.
Buying tips (from someone who’s tried it firsthand)
If you’re thinking about buying one, here are a few things to keep in mind:
Heating power – make sure it’s powerful enough for your space. I chose a 5kW machine, which heats up my tent in minutes.
Fuel efficiency – My machine runs for 8-10 hours on a few litres of diesel. Not bad.
Safety – Look for models with features like overheat protection, flameout sensors, etc. Don’t skimp on this.
Noise level – My machine makes a little hum when it starts, and it’s barely audible after that.
Portability – If you’re moving camp or going to different ice fishing locations, go for something compact.
How it works (without getting too technical)
Diesel in – you pour diesel into a small tank (I used a 10-liter one).
Air in – the heater pulls in air from the outside.
Combustion – it mixes diesel with the air, ignites it, and uses the heat to heat the air.
Hot air out – the fan blows the warm air wherever it’s needed – your tent, your camper, your igloo.
Exhaust – the fumes are ducted out, keeping you safe and warm inside.
Sounds more complicated than it actually is. Once it’s set up, you can pretty much just flip a switch and go.
Conclusion
Winter used to mean cold toes, stiff fingers, and sleepless nights. Now? I’m warm, energized, and actually enjoying my trips. My diesel heater has completely changed the way I experience travel. It’s not just about comfort, it’s about making those experiences more sustainable.
If you’re in the snow, trust me: get a diesel heater. You’ll thank yourself the first night you wake up without shivering.
Almost true! I know many people that use them, but there are draw backs.
Additional info:
Have more than one source of power required. i.e. battery source and diesel fuel.
When choosing a diesel heater consider the second source more closely, because lugging around a battery pack is also an issue. Full-timers (or at least many of them) have ditched furnaces for heaters because battery charge becomes to big an issue, with the trade off for convenience, becoming to great. Might I suggest a catalytic heater as a better alternative to a furnace?
