Inverter issue
Have you check the breakers in the panel and on the inverter?
I had a new inverter installed and now my generator won't run the AC or microwave. What happened?
Is an inverter a new thing for your rig? Or is it a replacement? If it replaces an older inverter, is it the same specs?
Oh!! What model inverter did you have installed?
I had my local RV repair guy recommend and install the inverter, which I know nothing about. I will check the model number and get back to you. When it didn't work after install they thought it may be a voltage regulator. They are no longer in business.
That says allot! Grab the model number and we'll go from there
