Inverter Location
Hack
Midlothian,Tx
Ventana / 3933
Spartan
330 HP Cummins
I have a Fault code on my Magnum Remote Inverter/Charger panel. Trouble Shooting says to do a Soft or Hard Reboot. My problem is, WHERE IS THE INVERTER LOCATED.
Probably in the center of the basement area between the frame rails and not too far from your battery compartment, tucked up neatly just out of sight if you are peering in to your compartments. On mine I would have to empty a compartment and climb in there to fiddle with it.
