Is Completely Lithium Possible?
Too Little Too Late
On my motorhome I’m charging a lithium house battery with a 60 amp DC to DC charger connected to a lead acid starting battery, and the battery combiner relay is disabled. It’s been working great so far. Now the lead acid starting battery is failing, and I want to replace it with a 100Ah lithium battery, so the entire coach will be lithium powered. I can reconnect the combiner relay because both batteries will be the same chemistry. But how am I going to limit the charge current to the lithium starting battery. Please completely ignore the fact that a 100Ah lithium battery is not designed to start a vehicle. I have removed that issue. So I have a 30 amp DC to DC charger for the 100Ah battery, but I can’t run two converters directly off the alternator without a battery in the circuit, right? How can I make this happen? I hope I’m painting a clear enough picture. One more time. I have a 460Ah lithium house battery charged by a 60 Amp DC to DC charger. I have a 100 Ah Lithium battery that I was planning on charging with a 30 Amp DC to DC charger. But what is my power source for these two lithium chargers? Can’t be the alternator, right? In a moment of desperation I tried connecting the alternator to the 460Ah lithium battery just to see what the charge current would be, and the 170 amp alternator was charging it at 135 amps. Not good. Too many amps. Any ideas about how this can be done would be great. Ed in Galt, CA
2007 Fleetwood Expedition
The prior owner of our coach did an upgrade to LFP on house and chassis.
Smart guy - but ended up putting the lead acid back in place for the chassis. Too
Many challenges with the chassis - this was on a Class 8 chassis for a SuperC, lots of alternator capacity but the hurdles were becoming dominoes so he cut his losses and put the chassis back to lead acid. The house Lithionics system is still running great 8+ years later.
Curious to see if others have figured out a way to do this.
Consider a super capacitor as your replacement without a Lithium battery for the chassis.
I kept the FLA chassis batteries in my 2007 Expedition which charge from the alternator, disconnected the combiner and replaced the Trombeta module with a BIM. My LiFePO4 house batteries are charged entirely from 1600 watts of solar.
