TXfreeze
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
For some time now we have had cooling issues with our Norcold 910, last hot season we were convinced that it had reached it's life expectancy. We had purchased fridge dual cooling fans on eBay but they weren't water proof and the elements got them and they were only 90mm fans. When the weather started to cool down and it was no longer 90's highs and 70's lows the freezer started to freeze again at one point it was at 10 degrees, the fridge in turn was in the mid 50's, so we knew it still had some life to it. So here we are again, same uncomfortable highs and lows. Now we purchased same kind of fridge fans but Titan waterproof 140 mms TITAN- 12V DC IP55 Waterproof Double Rack Mount Ventilation Cooling Fan with Timer and Speed Controller- TTC-SC20 (140mm) Amazon.com The instructions say to place the fan on the bottom so that it cools the inside and if there is a upper vent to place it in reverse, unfortunately the back fridge exhaust only has a lower vent. So the fans are placed facing outward to draw out heat. The fan speed is on high and all we have been able to maintain is 77 degrees in the freezer, outside it is currently 76. I've taken a a temp reading from in back of the fridge by the lower vent and indeed it is drawing heat out, but obviously it's been too hot out and the lows have not been low enough, I'm sure if we had a low in the 50's the freezer would once again freeze like it did before. So the big question is considering we can't get any lower temps in the freezer is it worth running a cooling fan in the warmers months or should we just return it and forget about the fridge in hotter months? We rely on a smaller mini fridge that works on a different principle.
