- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I'm running 2 x Pepwave BR1 Pro 5G routers. Pepwave 2 has an ethernet connected to its LAN port, this ethernet is going into Pepwave 1's WAN port. This allows me to take the Internet connections and use them on Pepwave 1 (WAN node).
As I've learned in my house, wired connections are best if you can use them. I have a 1 Gig FIOS service into my house and WiFi 6 is only giving me 1/3rd of that (something I may fix later with something other than Netgear crap). Regardless, this is the theme on networking these days, wired if you can, then wireless. As I have ethernet run from the AV box where my pepwave is to my dinette I put an unmanaged fanless switch in there to connect my Synology NAS (network attached storage) and two laptops (mac and windows). Giving me an ideal setup so I have no speed loss due to WiFi and max speed (1 Gig) between the NAS and computers.
All should work peachy right? Well, something is going very wrong. When Pepwave 1 is using it's WAN source (AT&T) everything works fine on all systems. I can download a 500 MB file with no problem. Now if I change Pepwave 1 to use Pepwave 2 as it's WAN source, the download will start and then fail about 5 MB into it (network failure or some message to that effect). I tried both Google Chrome and FireFox wondering if it was a browser issue. Same problem on both.
If I use WiFi and disable the ethernet adapter, all works perfect. So this is not an issue with cabling, something in the networking side is not jiving. I tried pass through options but nothing there worked to solve this problem. I realize this is a double router situation, double NAT but is not an issue when all done over WiFi, only cabled connectivity.
Any of you geeks out there have any suggestions as to what's going on and why connectivity is unstable or failing when feeding off of Pepwave 2?
