The list is endless. Leaks, air in system, or sensors needing adjustment, can be added to the above list.Try to find an owner's manual on Google for your jack system. I had the same problem a while back, located a manual for my system and found that just being a bit low on hydraulic fluid can cause that problem (not sure if yours are hydraulic?). I have also been told the sensors on the jacks are prone to fail, or they can get clogged up and give false readings. Hope this helps...
Thanks check fluid, didn't help, must be the sensors like you said. Thanks BobThe list is endless. Leaks, air in system, or sensors needing adjustment, can be added to the above list.
I suggest that you make sure your problem is just the sensors. I have a 2011 Winnebago with HWH levelers. When it was just a few months old I had the same issue. My fluid level was up but I also noted that the left rear jack had not retracted totally. It was low enough that if I had driven over some uneven ground it could have been damaged. Are yours all fully retracted? It turned out that there was air in the system. To correct it all four jacks were extended to the max then retracted and the again extended. That seemed to have "bled" the system and I have not had a problem since.Thanks check fluid, didn't help, must be the sensors like you said. Thanks Bob
Thanks Darrell, I will try this.I suggest that you make sure your problem is just the sensors. I have a 2011 Winnebago with HWH levelers. When it was just a few months old I had the same issue. My fluid level was up but I also noted that the left rear jack had not retracted totally. It was low enough that if I had driven over some uneven ground it could have been damaged. Are yours all fully retracted? It turned out that there was air in the system. To correct it all four jacks were extended to the max then retracted and the again extended. That seemed to have "bled" the system and I have not had a problem since.
Darrell
