Question KIB panel not showing correct voltage.
Rich-MLsRV
Colorado
Dutch Star
2020 Jeep Cherokee
On my 2024 DS 4081 the Victron Energy touchscreen monitor shows house battery voltage charge level of 76% charge level / 13.6V while the KIB panel shows 0 voltage. I suspect the issue is almost certainly a blown sensing fuse or a disconnected communication wire rather than an actual dead battery. The fact that the Chassis battery still reads 12.66V on the KIB panel suggests the panel itself has power, but it has lost the specific "link" to the House battery bank. I am thinking this is a blown fuse. Can someone suggest where to look for the blown fuse? I've "reset" the system several times turning off house batteries with no success. TIA
rich
Rich, Is anything else not acting right? Mine did that a few weeks ago and I ultimately cycled the salesman switch to fix it. But I did have a couple of other things not working exactly right. You might give it a try.
