Komfort 23' towable constant running sound in front of trailer
Kickstart
Eugene, Oregon
Thor Industries
Komfort 23T
23'
Hi, I'm new to these forums and this is my first post here. I recently bought a 23' Komfort (manufactured by Thor, I believe...) bumper tow trailer. I went out to where it is currently stored a couple days ago to run power to the trailer and charge the batteries. I notice in the front of the trailer there is a constant humming sound like a water pump (maybe?) is running constantly. I can't find any switches to control the water pump or any kind of a distribution panel. I unplugged the trailer before I left for fear something would burn up if I left it running.
Does anyone have any suggestions on what it might be or where to start on this? The shore water inlet is on the front driver's side of the trailer. This seems to be near where the noise is coming from.
I would really like to be able to just shut it off, as there is no water hookup nearby.
I can't help you with your issue but I just want to welcome you to the forum.
You will find that there is mostly a friendly atmosphere here and many knowledgeable folk. I'm sure someone will be able to help you
If there's water in the trailer, you should be able to power the trailer and run the water from a trailer tap and hear if the water pump turns on with the tap, and then back off when the tap is closed. The sound of a pump running is less of a hum and more of a muted rattle, but at least you'll know what the pump sounds like. If there's no water and/or there's a tap already open when the trailer is powered, the pump will run. Most RV water pumps are okay to run dry, so you shouldn't burn anything up or destroy the pump, if that's where the noise is coming from.
I had a camp trailer many years ago. When plugged in, the AC-DC battery charger was in a box of some kind near the front, and it hummed louder than I thought it should when it was charging the house battery.
Good luck with your trailer, and don't forget to enjoy it!
Greg.
Look for a switch on the kitchen counter,
Or maybe on the vent hood over the stove.
Welcome to RVforums. Once you find the culprit I would suggest a battery disconnect so you can totally disconnect power from the trailer when not in use.
Greg.
Thanks for the input. The trailer is dry, no water when the faucet is turned on. You're correct about the sound. A hum was probably not a good description. It's more like a rattle... It actually sounds similar to an electric fuel pump running, that's why I assumed it was the water pump.
I can't hook it up where it currently is parked, but will be moving it closer in to our shop when the rain starts, as it will flood where it is currently parked. So, if I understand correctly the pump will not burn up if running constantly... I may go ahead and plug it back in for now to charge those batteries...
Steve
I have looked everywhere I can think of. The only things I have found is a switch for the water heater (on the edge of the kitchen counter), and the instructional stickers inside one cabinet. I can't locate any breaker box or additional switches, other than light switches. There is a 30A cord for shore power inside one outside cubby in the rear, but no panel or box in there either...
Steve
That is a great suggestion. I will be doing that very soon.
Steve
Well, here is an update... I went out to the trailer where it is stored, plugged it in and took my time looking around. In the bedroom at the front of the trailer, in the bottom cabinet near the right side of the trailer (tow vehicle's passenger side), I located the water pump. When I was looking around in the kitchen, I noticed (right in front of my face the whole time) neatly concealed right before my eyes, the hood vent over the stove has a little bit more than just the controls for the hood fan and light... Voila! The control for the water pump and gauges for the fresh water, grey water, and black water! I've attached a few photos...
Steve
