Leprechaun generator only works when key is in on position
M Philibin
Hello,
I have a 2022 leprechaun 319mb. Had it out a few times now but this past trip the generator will now only work when the ignition is in the on position. Once on, it fires right up. As soon as I turn initial off the generator shuts off. House battery is fine and I’ve checked all the connections. Any suggestions? Thanks in advance
Welcome to the group.
Did you check the voltage on the coach battery. The research I’ve done points to the house battery being bad, low voltage. This is not a problem I have experienced…yet. I looked on other forums. Good luck, let us know.
How did this work out. Did you find the issue?
