Lessons learned Heartland TrailRunner 31db
Mark Francois
2021 Heartland TrailRunner 31db issues...
I learned that you cant trust the manufactures labels... Fist problem is that the inside monitoring station isn't setup the way it reads and the tank discharge labels aren't correct either...
1. On the monitor station, the black water tank button is actually the half bath sink and toilet but on the outside at that discharge it is labeled as gray water. Imagine my surprise when I empty that tank expecting gray water and its chock full of doo-doo lolol
2. On the monitor station, the gray water tank 1 is actually the kitchen sink and mater toilet but on the outside it is labeled as black water which is correct for the toilet but why the heck is kitchen sink attached to that tank? Doesn't seem correct to me.
3. On the monitor station, gray water tank 2 is the master bath sink and shower which makes sense and is actually labeled properly on the discharge.
4. Rear tank flush clamp broke allowing water to spray out inside the rear sink cabinet.
Now I was told and the brochure stated 2 - 40 gal gray water tanks and one 80 gal black water tank but that doesn't seem accurate due to what I found this weekend. Looks like I've got to call the manufacture tomorrow and see just what the heck I do have... Outside of that, everything worked as it should so no major complaints other than the above.
:oops: :oops: :oops:
Hi. Not sure if you’re getting this, but I just bought. 2021 Heartland Trail Runner 31DB last month and I am currently living in it. I have two flesh valve tanks on the outside and when I connect a hose to one water comes through my black tank, but when I run it around to the other side of the RV and connect a hose to the second flush valve. No water comes out anywhere. Do you know what that second valve is for? Do you still have your heartland RV?
