We're in the final stages of deciding between the lance 2185 and the Flagstaff 25BRDS. we're leaning flagstaff right now just based on the price. it sure seems like you get a lot for your money with the Flagstaff but the final hang up is clearance
WHen level the bottom of the front stabalizers on the flagstaff are 12 inches off the ground. As you can imagine in CO flat ground is an uncommon luxury and I'm very concerned about that little clearance with a number of the places I commonly go for elk/mule deer/moose.
So my questions:
1) Has anyone here solved this issue on a flagstaff 25BRDS specifically? If yes, what did you do and how much clearance did you achieve at the stabalizer jacks and at the axel?
2) Does anyone know of a lower profile stabalizer jack than the scissor jacks the 25BRDS comes with and have you installed them? If yes, what are they and what problems/considerations should I have in mind if I go down this path
3) THe 25BRDS has a torsion axel. the man at the dealership is telling us you can't lift those without thousands of dollars in work but I see kits to lift torsion axel campers online. is there a nuance I'm missing or is this guy just completely full of crap? Any problems or concerns with lifting a camper with torsion axels that I should be aware of?
Thanks
So my questions:
Thanks
