Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I just checked the notifications on My phone after My self imposed time limit here,but had to extend that time. My notification From a RAM forum was there so I opened it up. Someone else that believes you can't go wrong using AI cut and pasted a Google AI response pageYou best consult AI before posting. This is exactly the problem we are having in these discussions. The resident pundits immediately type stuff originating from their restricted fund of knowledge and experience. Most often before I type anything these days I test my knowledge and memory with AI. Our discussions would be much more helpful to other people if everyone did the same. None of us are as smart as the collective wisdom of many.
My F-150 PowerBoost is a 7,350 lb truck.
From AI. I have never seen a 7,400 PowerBoost so AI may have this wrong but close.
The 2024–2025 Ford F-150 PowerBoost (hybrid) typically has a Gross Vehicle Weight Rating (GVWR) of 7,350 to 7,400 lbs. As the heaviest F-150 configuration, its curb weight is approximately 5,500+ lbs, leaving a payload capacity around 1,700–1,800 lbs. Always check the door jamb sticker for exact ratings.
Key Weight Specs for PowerBoost:
- GVWR (Gross Vehicle Weight Rating): Generally 7,350–7,400 lbs.
- Curb Weight: ~5,517–5,540+ lbs (varies by trim/options).
- Payload Capacity: Max is ~1,735–1,830 lbs.
- Towing Capacity: Up to 12,700 lbs.
Honestly, I got a kick out of the fine print at the bottom of the response. This is what it says.
AI can make mistakes so double-check responses
What I found very interesting is Google was very careful to put that statement in it's own un-copyable container on the web page.
So basically folks! Google admits that there AI engine is no better than a forum.
The other thing I found interesting was the data that it offered up was a sales release. That proves again that slick salesman are leveraging AI to hood wink people using AI be wary.
