LIght switch problems
Odetymes
Strange one......just had eight house batteries installed all well. Noticed today that when I turn on the bedroom overhead room light, it doesn't work nor does one other part of the switch (vanity). The switch works on the two other connections just fine. I tried to turn on the bedroom from the front switch and it still doesn't work. The front with works on all connections just fine. I've checked the fuses and all seem ok. I'm perplexed as to why the back bedroom switch works in part and one that is 36 ft. away! Any ideas to trouble shoot further? Thanks to all!
We could help more if we knew what year and model coach you have.
When I have strange behaviors like that, one of the first things I try is to reboot the KIB controller which ties together all those switches and the lights themselves. The easiest way to reboot the controller is from the house battery disconnect switch which is typically located near the entrance door. Turn it off for 5-10 seconds and see if that resolves the issue.
it did and thanks.
