Continuing to baseline LightShip 4. I am ramping up road testing in the lower deserts of the SouthWest. For next week we are going to have temperatures in the 90's, so Summer time conditions for the testing over this period.
I took LightShip 4 to the CAT scales for the first weigh in. I will do a more detailed weigh in later looking at before and after weight distribution weights but for now I wanted a base line before loading in all the cargo associated with typical camping use.
So here are the conditions for this weigh in.
1. No cabin load, just as It was from the factory.
2. 480 lbs of water, 400 in the water tank and 80 in the hot water tank.
3. Factory Curt load distribution hitch set up with 5 chain links used.
4. Hitch weight before hook up was 680 lbs.
5. For PowerBoost Platinum empty weight 6,063 lbs, giving max load of 1,237 lbs.
6. Estimated Powerboost bed and cabin load for CAT weigh in 350 lbs.
So backing into the empty weight of the LightShip you start with the CAT scale weight on the four LightShip tires of 7,440 lbs. Next subtract 480 lbs of water to equal 6,960 lbs. Next add back 680 lbs of hitch weight and the empty weight is around 7,650 lbs.
But there is one more adjustment. I know from experience that weight distribution hitches will move about 200 lbs from the truck back to the trailer wheels, that would come to 7,450 lbs empty weight of the LightShip. And finally there is the 100 weight distribution hitch whose weight is shared by both the LightShip and the PowerBoost.
Bottom line, I know for sure before adding cargo the LightShip and PowerBoost combine gross weight is 14,420 lbs rolling down the road. I think the stand alone LightShip empty weight for this Cosmos model is probably pretty close to the specification of 7,300 lbs, maybe a bit more.
