LightShip Systems Review - Aerodynamic Enhancement System
Any available info (or informed estimates) on how the drag of the Lightship compares to Bowlus trailers?
www.bowlus.com
Hi Josh - curious the feedback of others with real world experience. @turbopilot ? I can reach out to a contact I have who is considering a swap to a Lightship.
From our engineering teams here, the key differentiating features:
- blunt shape at front of bowlus is not as good at reattaching the air coming off the tow vehicle (compared to tapered like lightship)
- frontal area is much bigger than lightship
- camm tail shape (lightship) is better than wedge to detach air cleanly
we have some estimates here internally at the difference in drag, but wouldn't want to share those publicly as not validated/proven.
I have no experience with the Bowlus. But given LightShip has a very refined force sensor (on the hitch of the LightShip) and associated hardware/software, there is no reason a "Portable Force Sensor" could not be easily fabricated and placed between the tow vehicle and any brand of trailer for a tow test. The force sensor can read the force necessary to pull the trailer (in Newtons). Once you have the force required to pull the trailer you can back into the hardest number to calculate without a wind tunnel: the Coefficient of Drag.
So there is no reason LightShip could not easily calculate the Coefficient of Drag for every make and model towable RV on the market with very little effort. Could even offer a service to anyone with some other brand of towable to come to the factory and get your Coefficient of Drag measured (along with a sales pitch :) )
The drag equation is simple to calculate once you know the Coefficient of Drag for a trailer.
The drag force (F_d) is calculated using the standard aerodynamic drag equation:F_d = ½ × ρ × v² × C_d × AWhere:
  • ρ = air density
  • v = velocity
  • C_d = coefficient of drag
  • A = frontal area
I also think it would make sense to display the real time force measurements from the force sensor on the LightShip in tow on the Atlas tablet. There are so many variables impacting drag force (speed, wind, cross wind angle, temperature, altitude, tire pressure, rain, snow etc), displaying the force actually experienced in real time, at the hitch, towing a LightShip would be valuable information for the driver because that directly impacts range.
In conclusion Gemini AI's verdict is the Lighship totally wins on total drag force at hwy speeds because its lower frontal area displaces less air at hwy speeds.
However, the Bowlus likely has a lower pure drag coefficient because its permanent fixed shape is more purely raindrop and lacks the mechanical seams of a telescoping roof. Furthermore, the boat tail design of the Bowlus is more aggressive than the tail design of the Lightship at minimizing drag at hwy speeds
* Lighship's stated goal was to achieve a drag coefficient comparable to a Tesla model 3 which is ~0.23, however this is an aspirational benchmark rather than a confirmed figure for the trailer itself.
Your premise is wrong. No such claim was made by LightShip. The claim is that the output of the drag equation, in newtons, is the same for a LightShip in tow and a Tesla Model 3 rolling down the highway at 62 MPH. Obviously the coefficient of drag and the cross sectional flat plate area of the Model 3 and LightShip are different.
But all this has been proven empirically, not by wind tunnel tests. The towing tests have repeatedly confirmed that the LightShip requires 250 watts per mile delivered to the trailer wheels by the electric motor, at highway speeds, in tow, to cancel forces measured at the force sensor on the hitch. This is exactly the same power needed to propel the Tesla Model 3 down the highway. So the output of the drag equation has to be the same for the Tesla Model 3 and LightShip. The key variables in that equation are frontal area and drag coefficient which are obviously different between the LightShip and the Tesla Model 3. But the output of the equation (in Newtons) has to be the same, ie 250 watts required for every mile.
But the bottom line is that the same amount of energy is required to move a Model 3 and a LightShip (in tow behind a tow vehicle) down the road at 62 MPH.
As to the Bowlus, a rough comparison could quickly be made by towing a Bowlus (or any conventional towable RV) with an EV tow vehicle. Take the EV tow vehicle over a measured course alone without towing and determine the watts per mile consumed. Then immediately tow the Bowlus over the same course and get the kilowatts consumed. Then convert the difference into watts per mile for each situation.
This has been done by several owners of the Pebble Flow EV trailer which has an aerodynamic shape but high frontal area. The reports I have seen suggest the Pebble Flow requires watts per mile somewhere between the LightShip and an Airstream. I suspect it would be close to the same power consumption required by the Bowlus.
It’s not a premise and Ben Parker said it at SxSW. He didn’t say it has the same coefficient of drag as the Tesla or that it would but that it is the aspirational goal as is in your reach should exceed your grasp. In 2023, however he did say that in computational fluid dynamics simulations the L1 was at the same 0.23 coefficient as the Tesla model 3.
The trouble with this issue of a constant like the Coefficient of Drag is that there are really two different trailer CD's. One CD is the computed value in a wind tunnel in free air for the LightShip (or any trailer). Of course this CD is entirely fictional since a trailer cannot move at highway speeds in free air because it has to be towed.
The second CD for a trailer is the calculated value when the trailer is running in the wake of a tow vehicle, because the tow vehicle is now enhancing the aerodynamics of the trailer plowing through the air. And to complicate it more that "towed CD" will be different for every tow vehicle type pulling a LightShip.
This whole analogy was started to demonstrate that a LightShip behind a pickup tow vehicle required the same amount of additional energy from that tow vehicle as did a Tesla Model 3 moving in free air. And that was without TrekDrive ON. With the electric motor engaged it delivered just enough energy to cancel that 250 watt per mile demand on the tow vehicle, returning the tow vehicle to the same efficiency as it had not towing at the expense of the electricity needed by the LightShip.
So the computational fluid dynamics simulation back in 2023 is interesting but that was all done when LightShip was a concept, not a reality actually being towed on the highway. Now we know with actual towed data that the simulations were near perfect in terms of the predicting outcome, the energy required to move the LightShip behind a tow vehicle. The individual variables leading to finding are complicated and not directly comparable.
Bowles is claiming the aerodynamic enhancements reduce the range of a typical EV tow vehicle by 25% but of course it all depends at what speed that measurement was taken. All claims of aerodynamic efficiency have to stated with the speed used to measure the stated number. Drag increases with the square of the velocity and efficiency will decrease proportionate to the speed.
Here is a new walkthrough video of the Bowlus. The model in this video has a price of $280K, $96k more than the LightShip Atmos, but it is not self propelled, it only has a 19 kWh battery (versus 77 kWh in the Atmos) and a minimal solar array (compared to 1.8 kW in the Atmos). But it is light at 4,400 lbs GVWR, so it can be towed by a wide array of vehicles.
Making exaggerated claims is what you do in product promotion, ie., 4 occupants in an L1 can camp 7+ days off grid with a 35 gal. grey tank, a 30 gal. black tank and 50 gallons of fresh water.
I have never seen LightShip make any such claim about the duration of consumables (water & waste) other than electricity for the LightShip. They have clearly stated their expectation is that the combination of the 77 kW battery and the 1.8 kW of solar could sustain the LightShip with appropriate caveats. Single biggest consumer of power is the HVAC system. Obviously the large LightShip battery will not last 7 days sitting in Phoenix during the Summer time.
Here is LightShip's answer to this question in their FAQ's.
You continue to participate in this owner's group making inaccurate statements and assertions. I am just a customer but you do no credit to the forum with this kind of participation. It confuses new forum participants, adds no value and it basically trollish activity. You have been repeatedly admonished by the moderator for your behavior. Stop.
Both Ben Parker, CEO & co-founder and Toby Kraus, President and co-founder have reinforced in interviews such as with the "Fully Charged Show" that the trailer is designed for a week off grid. Lightship representatives at "Stressless Camping" claimed the trailer's "HOLDING TANKS" are designed to support a crew of 4 for 7 days off grid.
Both Ben and Toby, during the vehicles launch emphasized the trailer is purpose built to eliminate the need for fossil fuels and noisy generators, "ALLOWING A FAMILY OF FOUR TO MAINTAIN THEIR RESIDENTIAL LIFESTYLE IN THE WILD FOR A WEEK". (not many dump stations in the wild).
Tony Fadell, the inventor of the iPOD and founder of Nest and who is a major investor in Lightship has made similar claims when promoting the brand.
Industry experts quibble less with the energy claims ( as long as the a/c is not being used) than with what they term the "TANK TRAP". The L1's tanks are highly unlikely to support a crew of 4 for 7 days off grid.
My own tanks are 72 gal fresh, 41 grey and 52 black, none of which are going to support 4 people for 7 days of off grid residential lifestyle much less unfortunately a trailer with 50 gal fresh water, 35 gal grey and 30 black.
The Bowlus claim of a ~25% reduction in range for the towing vehicle is perhaps plausible. I towed a Trailmanor with a similar weight and much lower profile but square box front and roof top a/c, however with a 6 cyl. ICE vehicle and saw a reduction in range of ~27% at hwy. speed. Even though an EV is 20% less efficient lb. for lb. towing than an ICE vehicle the Bowlus profile may account for overcoming some or most of that 20% disadvantage.
Thanks Holdmybeer. I must admit I am less experienced and skilled than many others here, so I tend to look for simpler answers when possible, while trying to keep variables the same to the greatest extent possible.
I too have read about numbers in that similar range of ~25% range reduction for the Bowlus, and it's great to hear your personal experience with a Trailmanor at ~27% range reduction at hwy speed.
Neither the Bowlus nor the Trailmanor have a "vehicle assist motor", so I'm curious for the LightShip (and other competitors like Pebble and the EvoTrex), if any official (or unofficial well-informed folks :)) can give a rough estimate range of the percent range reduction at hwy speeds when the vehicle assist motor isn't being used.
(aka a more pure indication of how aerodynamic it is while being towed)
Rory on the Lightship team is currently towing one of their models on a cross country trek, I think he has data for range with and without the TrekDrive on. You might want to engage with him.
