Tip Link or Modify Attached Images
Administrator
Cummins 400 HP
Another great feature of this forum'ware is what you can do with attached images. Other forum'ware you simply attach images and you're done. When you attach an image on this forum you can inline the image as a thumbnail or full size image using the options after you attach/select the image. If you don't then it will be added an an attachment. However, try attaching your image and then insert the full image into your post. Now select the image and notice a toolbar at the bottom of the image. You can add a hyperlink to it so if someone clicks the image it will take them to where you want or you can do other options per the toolbar buttons.
Just want to remind people of this forum feature where once you attach a picture you can then choose to include the full size image inline with your post. You'll see two buttons after an image is attached as shown below. I recommend for most cases to use the "Full image" option and this forum'ware will size it to fit the width automagically. Up to you how you want your images displayed but just an FYI to this feature. You can go back and edit posts if it hasn't timed out for editing yet and choose this option if desired as well.
