Loose mirror mounts
Dona40
RVF VIP
Oregon
Thor
Tuscany 40DX
Freightliner XC
Cummins 8.9
Jeep Grand Cherokee
Greetings all. I have a 2016 Thor Tuscany 40DX with a loose drivers mirror mount. From the inside it looks to be attached by 4 screws from the outside. I can't see how to get the chrome trim off to gain access. Anybody run into this before? Not a lot of info out there. I just want to take care of it before it gets worse.
You might see if YouTube has any videos for this.
My Holiday Rambler has a shaky passenger side mirror. T tried to remove the chrome cover on the base but there is no apparent way to get it off. But if you look inside the generator compartment when you pull the generator out there us a big lag bolt that threads into a piece of 2x4 wood that it part of the framework of the front cap. It you take a pair of vice grips you can turn the lag bolt and tighten it into the wood. This tightens up the mirror base. Maybe yours is the same design?
On my Monaco I had that problem, had to remove the large arm with mirror from the bracket and the chrome cover slipped right off exposing the 4 lag screws
How did you get the large arm with the mirror off the bracket?
Bolt on bottom side
I'm assuming there is a cover over that bolt that also must be removed?
Here's what my Holiday Rambler mirror arms look like. Very similar to your Monaco I'm sure since my coach was made by Monaco. You say to remove the small circular cover that will expose a bolt. Remove the bolt then I can remove the mirror arm? After the arm is off I can remove this chrome cover over the base? That is where I'll find the lag bolts that go through the fiberglass front end cap into the 2x4 wood on the inside of the generator compartment?
I could never figure out how to get the chrome base cover off. The screws were all hidden. Look at the last picture. This is the tip of the lag bolt coming through the 2x4 inside the generator compartment. I used a pair of vice grips to turn this screw to tighten it. I couldn't see the other 3.
I see that my mirrors have the same bolt behind that hole plug. didn't see that at first. I haven't had the time to mess with it yet but I'll get to it soon.
Thanks ya'll
Now I've got something to do today!
Got it! One plug, One bolt, two electrical plugs Lift it out of the hole and tighten four screws Easy-Peezy
I have the same issue right now on my 2015 Thor Tuscany. I removed the cap and the bolt but the arm doesn’t budge. Any ideas how to get it to move?
Just loosen the bolt a couple turns and smack the bolt head with a punch. The adjustment pieces corrode together.
