Man I’m tired of these rotten DEF systems
J&JD
Fremont, California
Dutch Star 4018
40’
Cummins ISL450
Jeep Wrangler Sahara
Beautiful 4 day stop at a really nice new rv park in Northern California. All packed up, everything secured for the trip home. Fire up the Cummins and damn if it doesn’t throw a check engine light and a message saying “low DEF”. My dash gauge shows 2 bars in the tank and I know there’s at least 1/2 tank as I had just visually checked it. Drove about 40 miles and stopped at a truck stop and filled the 13 gallon DEF with 7.5 gallons of truck stop DEF. Obviously I wasn’t low on DEF.
Drove about 20 miles with the check light on and all of a sudden the light goes out and the DEF gauge is back up to full (4 bars).
I’m on my second DEF sensor and now I’m worried that this one is going bad after just 20k miles. This is just stupid, poor engineering that should never happen with a system as expensive as this one.
In my opinion this DEF System is a wacky lab fix that escaped before or even ever ready for commercial applications.
Government dictates driving bad systems.
Early catalytic converters suffered similar problems that were finally fixed with widespread adoption of electronic fuel injection.
I think you would benefit from carrying a DSS with you because eventually this could lead to derate and all the fun that comes with it. You’ve probably seen this many times before but here it is again anyway: DEF Sensor Simulator
Yeah Joe you’re right - this was forced on the public long before the engineering was sufficient to develop reliable systems. And to illustrate that point, they had to exempt emergency vehicles and because it was considered an “undue hardship”, agricultural equipment as well. I’ve always said that it is also an undue hardship to have your home on wheels leave you stranded by this equipment but apparently we don’t have a loud enough voice. Fortunately around 12 years after the mandate they finally appear to have developed a reliable system; time will tell.
I do carry a simulator. I was/am hoping that I will not have to utilize it. Still doesn’t give me much piece of mind concerning this sad system.
I also carry a new DEF head. Has anyone tried to replace the head themselves? Can it be done without removing the tank on a DS 4018?
I considered it on my London Aire, and then quickly reconsidered it. Not a job I would want to take on.
@J&JD any updates on your situation?
No real updates. I’ve been waiting on a back ordered DEF filter before I replace the fluid in the tank with fresh DEF. We have a short trip (80 miles) planned for the 19th hopefully there will not be any warning lights. I have mounted my def head simulator in the compartment so I’m ready just in case. I’m also considering installing a ball valve on the tank heater hose. Thanks for asking.
FWIW, I watched as the road mechanic replaced the DEF head on our '19 4369. Took him all of maybe 15 minutes of actual work time. He was able to access everything needed from the top without removing anything. Clamped the lines, and swapped heads.
It's sickening how many of these things fail...and the newers never seem to hold up; despite the manufacture saying "oh..this is the Gen x and it's better now." They said that way back on Gen 4 and now I think they're on like Gen 8. Geesh.
R&ring the head in my 17DS 4018 does not look like an easy job. No room to just pull the head out without dropping the tank and dropping the tank with all the connections looks pretty tough. Not sure I want to tackle the job.
