Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
Typically I’ve found that, if you have adequate power, and a microwave refuses to energize, it is something simple, burnt thermostat, diode, fuse. That said there are many items that can hurt you inside a micro wave . Capacitors hold enough energy to give you a very bad day if you complete a circuit. if you chose to open the unit up make absolutely sure that the capacitors are drained. A repair manual will go through the steps. Below is a troubleshooting guide I use to cover potential problems
- Diode – converts A/C to D/C
- Door switch – Notifies the rest of the microwave that cooking can occur
- Magnetron – Uses the D/C current to make microwaves. Microwaves cook your food
- High voltage capacitor – Along with the diode, converts A/C to D/C
- High voltage transformer – helps converts volts to power the magnetro
- Thermal Fuse – monitors the microwave for overheating
- Thermoprotector – Also monitors the microwave for overheating. The Thermoprotector will prevent the microwave from starting
- Main control board – This is the brains of the microwave. controls everything from cooking time to cooking power and turntable rotation.
