Thank you. Not worried about being enough engine heard and read some info saying the engine itself was junk. I’m looking at buying a Tiffin Breeze and was worried. I am getting a full warranty for the 2015. So I guess I shouldn’t be over worried. I’ve only owned tag alongs. I appreciate your fast replyDo the power to weight ratio calcs and see if it meets your needs. IIRC it was around 300hp/600tq, so depending on what its pulling or pushing, you might find it lacking. It was a lot less troublesome than the 6.0 but still had some issues worth considering. If all is well with it and it had proper maintenance, 33k is barely at the break-in stage.
Awesome thank you. 200k nope. I probably won’t make it that long. I appreciate everything. Thanks againIts been a very successful engine rated at over a million miles when properly maintained. It did have some problems including cracked pistons but as noted in the article below :“In most cases, it occurs in higher mileage engines or engines that’ve seen years of accumulative (sic) abuse.“ If you think your Breeze will see over 200k and you plan to run long oil change intervals then it may be an issue.
I’d change the oil every 5k and check the oil often to catch any instances of fuel in the oil (from a rather poor DPF regen design). If you do see that the oil level has increased due to the regen issue, just change it and be on your way. I can see this being an issue if ignored, but that would fall into the operator error category.
But most of the other problems the engine is famous for are really Ford problems in trucks and your Breeze will have completely different cooling and exhaust and probably turbo systems so those issues won’t apply. Do the research and reach out to other Tiffin owners. I suspect that in a well taken care of truck chassis it will more than go the distance for an RV.
6.4L Power Stroke: Long List of Failures
From leaking radiators and cracked up-pipes to oil dilution and K16 pump failure explore every common 6.4L Power Stroke problems.www.dieselworldmag.com
