New Fleetwood bounder 35k wifi
Twintails150
Hi all my wife and I purchased a 2023 bounder 35k and are having a huge issue trying to have Wi-Fi. We called Verizon and they have no clue. We have the wine guard unit and Wi-Fi ranger but I’m clueless from there to what to do can some one help? I tried calling the dealer and no help I tried Verizon and wineguard and no help
Hello, new to our 2021 Fleetwood Flair 35R. No luck from dealership on anything in the RV. I found information on the wifi ranger on-line after a lot of time researching. The Wifi Ranger is an actual Hot Spot. I had never used a hot spot, so what I found out is:
1) Connect device to wifi ranger in RV: Find your "RV" wifi ranger router name and attempt to connect to it's wifi signal. The password is usually the same as the name of the wifi ranger without punctuation i.e. REV_RVxxxx pwd would be REVRVxxxx). Pay attention to capitalization.
2) Find wifiranger set up page for wifi: If you can connect to the wifi ranger, then using the connected device, go to url "mywifiranger.com". This will only work if your device is connected to the RV wifiranger.
3) Set up wifi ranger for wifi Hot Spot: This should bring up a difficult to use page that you now select what actual wifi provider/source you want the RV to connect to and connect the RV to that provider.
4) Use RV hotspot: Once wifi ranger has connected to the wifi provider, just connect any additional devices to the wifi ranger hotspot.
Hopefully you are a little better at device connectivity than we are as it took me a lot of time to figure this out.
