New to Class A
Mare
Michigan
Winnebago
Vista
Ford
Gas
First year with our Class A, we are winterizing the Motorhome. Bought a cover, but we were told should start it every week for the batteries and generator. That is going to be a pain having to keep moving the cover. Any recommendations?
Some questions first: What are you protecting your coach from? What part of the county are you from? How tight does your cover fit?
If you were to complete the info on your profile we would have more info that would help us.
Thanks
Thanks
We live in Michigan (US)the RV sits outside. Protect it from the harsh elements. Just bought the cover, putting it on today. Suppose to fit a 30 to 33 ft RV.
Okay. No salty air. That's a plus. The minus (s) are wind, and snow. Since your cover is not going to be tight fitting. No matter how it is lined you will probably have some "flapping" going on which is detrimental to paint and trim. Loosening the cover to get access to the inside sucks!! When it it cold, and I'm sure Michigan gets pretty cold, you will have a harder time snugging the lines as the material does not stretch like it does when it is warm. No matter how much we tried. it just didn't snug up well again.
We used ours for one winter then tried to be more careful the second. Mid December we cut the ties and tossed the cover. There was paint damage on the front corners by the w/Shield. The cap that covered the awning end up front was cracked and both mirror covers (not painted but black plastic) were rubbed raw. That was the first year. The second was causing the same issues. After that we gave the coach a good coat of wax before putting it away and we were much happier.
I can't remember the name of the company that produced ours but it had a soft and fuzzy lining that we thought was great. We also custom ordered it fitted for a 28. You can see from the photos that there was not a lot of folding going on. I hope you have better luck with yours.
Wow, I hope that doesn't happen either. We decided to remove the batteries and see how it goes this winter. Good luck to us. Have a great winter. Thank you for your insight.
So here is my Newbie Rookie experience and I hope it helps. The first winter with our motorhome a 2007 Encore 40TS I bought the best cover out there. I went out and started it monthly and let it warm up. Big mistake. I went to pick it up in February to take a trip South. What I thought would be a quick pull off the cover and go turned into an all day event because of a rookie mistake. Starting the motorhome and letting not only the engine but also running the furnaces caused an ice layer on the roof under the additional 6-8" of snow. The result I had to tear up the new cover to get it off. I tried heating the rig up but there was so much ice on the roof along with the snow and very cold temps there was no thawing it out. After multiple hours of working with getting the cover and ice off I finally was able to move the coach and get it home. That was the last cover I ever bought and the last time I ever warmed up the house while cycling the engine. Also unless you are going to actually drive the rig starting it dos not really help you at all. If you can put a good maintainer charger on the battery system. You can also turn the battery disconnect to the off position to prevent parisitic drain on the batteries
Good morning.
We also live in Michigan. Nothing beats indoor storage for keeping units protected from the winter elements. The additional cost could easily be made up with less spring and long term repairs. It does not need to be heated storage, just out of the elements. As for the batteries, GENERALLY, if you store with a full charge and remove the negative cable, you should be fine. We had one spring with a dead crank battery and a jumper box handled that quickly.
Have a good day.
Ken
