Yowza. Go get a TPMS Monitor. A big cause of blowouts is usually under inflation. Sometimes over inflation but more often under. Once your 5er is loaded up the way you plan to travel with it, including tanks, get a four corner weight and then pull up your tire manufacturers tire chart and adjust your tire pressure to what the chart indicates you should use for the weight you are carrying on each axle. I usually add 5psi on top of that to provide myself a little cushion.
I don’t know much about your unit but if you bought new, I assume there is an owners manual. Is there a section on cold weather operations in it? Do you have any control panel switches for “heating pads”? Open your wetbay, can you see anything that looks like a heater or convector in there?
