Buly
- Nov 3, 2019
- TGO Titusville FL
- Dutchstar 4369
- 2014 Honda CRV
AMENthis is all school of hard knocks stuff and not research or the advice of techs or the result of a seminar or whatever. But I figure for the cost it’s cheap insurance and my passion about these emissions systems starts and stops with avoiding ever being stranded by the complexity and fragility of them again
It didn’t matter it didn’t leak much just have a rag ready I changed mine every 2 yearsDo you change it on an empty tank? Or it does not matter?
I was going to ask FL at Gaffney to do it.
I have a 2014 king aire. Spartan chassis. Would this fit mine?If its Freightliner, and maybe also for Spartan, the filter is located on the pump, behind the round cap on the center/right side of the pic. The pump (called a DEF Supply Module) is usually located at the bottom rear of the tank (facing the filler neck). The filter is available for around $60 if it says Bosch on the box, or around twice that if says Cummins (also Bosch). Having already experienced a pump failure, I carry a spare. Here’s a link showing a Bosch filter for about half price:
Your part# may be different of course.1457436033 Bosch Urea DEF Fluid Filter - Diesel Pro
1457436033 - Bosch DEF Fluid Filter Kit. UF101, 68087337AB, DZ114640, RE554498, 2888182, 3955034, 5303604, 21516231, 23381558, 21376699, 21496421, 21673818mydieselpro.com
It might but I doubt it. Spartan uses different DEF system components from a different manufacture. But it should be easy enough to find the right part number.I have a 2014 king aire. Spartan chassis. Would this fit mine?
