Oasis Chinook Electrical Schematic
Just George
Texas
Dutch Star 4369
Freightliner
Cummins ISL9 450HP
2023 Silverado
One of the electrical elements on my Chinook is not activating i.e. no current draw when the element is selected on the control panel.
Have not opened the unit or begun to troubleshoot yet but would appreciate any electrical wiring info anyone may have.
Anyone know what the electrical resistance should be on a good heating element?
I've worked with ITR troubleshooting other issues in the past so I know there is help there but thought I'd check here first.
Thanks in advance,
I've been through far too many issues with my OASIS including electrical. Kill the breakers (2) and use an electric pen to ensure no power is coming into the unit.
You'll want to inspect wiring where the 120V is coming into the unit (top side).
Remove the hour meter and inspect wires below that and also review the wire connections, some of mine broke at the spades, corroded, etc.
Open the front panel of the unit. You'll see the 12V relays on the lower left. One of these failed on me, ordered a replacement and spares from ITR. They are very cheaply made. However, follow the wires as they come down the left (forward) side of the unit to the relays, make sure all are intact and you can test.
ITR has a procedure for testing the relays, I can't remember what that is. I think it involved swapping the two to isolate one was bad. But you can ensure the connections are secure into the relays, etc. I probably have write-ups on my issues from each occurrence if you search the forum for OASIS.
If anything else jogs my memory I'll add. It's not an overly complex system. Just have to do a good wire inspection as they corrode, come loose, wires have had burn throughs, etc.
Neal is correct. I have also had wires burn through and fail. And I even have a different model. Follow the wires and you will probably find the culprit. ITR is also very helpful if needed.
Thanks to all for your input. I finally was able to trouble shoot my element issue this weekend and thought I'd report back. All electrical connections are good. No signs of excess heat, loose connections etc. The electrical path is pretty straight forward. 120V comes into a thermal switch, then to the activation relay then to the element. In my case the element is bad. There was some visual evidence (black ??) on the face of the element nut. Confirmed the electrical circuit with ITR, unfortunately the element is out of stock so actual repair is on hold. ITR says I need a 40psi pump to pump the boiler fluid out and back in. If anyone has purchased a pump that works please let me know a part number & source etc. Thanks, George
Do you have to drain it to replace the element? This is the first time I have heard of an oasis element failure…
Interesting.
Interesting.
Yes sir, have to drain ~ 7 gal of boiler fluid. The element(s) are at the bottom of the tank.
Wow….did not know that! That is a real drag….as I have 14+ gallons if that happens to me.
I think @Chuggs replaced his transfer fluid and bought it somewhere, affordably, in 5 gal containers. His post is on the site somewhere.
Actually camping worlds price per gallon is the best I have found.
Conta
Contact
Erin Manoloft
Mix with Distilled water 3 to 1 makes 15 gallons.
This would come out to roughly 15 gallons of heat transfer fluid once all mixed, mixture would be 1 part heat transfer fluid concentrate to 2 parts distilled water.
Good to know!
We happened to be in Indiana visiting Nappanee...so, drove right over to Century and picked up three pails of pre-mixed.
I found fluid on Amazon from Recpro. The main page shows a quart of concentrate for $44.95 (to high). I clicked on it to see if it was a little cheaper for a bigger volume. I bought for quarts of concentrate for $44.95. So that gallon of concentrate makes three gallons. About fifteen dollars per gallon. Not a bad option if you are not doing a total system replacement.
