Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
Shoot, I knew it. You guys are talking me out of buying an RV again.
I had these concerns when my son was little and came to these or similar boards. Came to the conclusion that RVs aren't safe for children and decided not to get one. Now I'm feeling the same way but not just for children, for everyone. Driving two vehicles is not an option.
So... the welcomes aren't really necessary since I likely won't be staying. RVs are unsafe. Thanks.
I admire your caution...but I wouldn‘t recommend analysis-paralysis.
Do the things that you can control to make rving safe.
1) When you get behind the wheel...leave all distractions behind. Focus on moving that RV safely and conservatively down the road. Did I say FOCUS!!!???
2) You must be in control. Control over driving distances...route choices...time of day...speed...safe following distances...careful selection of lanes...proper use of signaling.
3) You’ve heard of the two second rule? Now you need to consider using the five second rule. Leave plenty or room to detect an object, or slowdown and take smooth corrective action.
4) Plan ahead. It helps to have your plan of attack. There isn’t a safe way really to juggle a map and drive all at the same time. If I need to alter from my route...I use the Voice Command feature of my GPS to reroute or change destinations if needed. If that doesn’t work...pull over. Figure it out while not driving.
5) Keep your equipment in good shape. Tires, their condition, and proper inflation can save you from the most common challenge to safe operation. Avoiding a blow out. Lighting, Emergency markers, fluid levels, avoid overheating, etc...
6) You can do it...you can do it safely...and most of all you can have a wonderful experience. You have to let in some pleasure though. If you get too wrapped with fear of something bad happening...you won’t enjoy this as much as you could have. It is also very important for YOU to keep it all FUN!!!
7) Towing. I see more accidents posted on social media where it appears the item being towed had more control over the rv than the rv. Don’t tow overweight. Make sure your equipment is properly rated and in good repair. Know that sudden wheel inputs can ‘crack the whip’ so-to-speak on whats behind you being towed and will create a fishtail which negatively effects control of the RV.
I have been told...RV’s come with seatbelts equivalent to the number of people the unit can sleep. Not counting the extras on the floor with aero beds
Again..you are way ahead of the game thinking about safety. Kudos. Just don’t let us lob fear grenades at you and talk you out of an enjoyable family pastime. At least, for us...RVing is all that. We get to see places, meet really cool and interesting people, without having to stay in a Holiday Inn Express.
