Passenger side window replacement and resealing windows with new butyl tape
Roadglide117
RVF VIP
North Lima, OH
Ventana 4381
Freightliner
400 Cummins
28' car hauler or 2019 F-150 4x4 Sport
I have a 2015 Ventana4381. I'm wondering if anyone knows of a window replacement for passenger side that has a slide window to get air in?
Also need to clean between my glass on several windows. What size butyl rope tape does the factory use. I could call Newmar if I felt like waiting for a call back. Thank you in advance!
Can't help about the replacement other than calling Newmar for the make and product number. I did and found out our windows are produced by Lippert.
In late Feb we have an appointment at Suncoast Designers in Hudson FL. for repair on some our our foggy windows for $562/window. They are known to do a good job and warranted for life (for original owner). Lippert has a 2 yr warranty.
There's another company who's also respected but don't recall the name. A search might produce results.
Thanks..I plan on doing it myself...$200-$600 a window is a little pricey.
I'm pretty handy and after watching youtube videos, I thought I could do it. Per another forum, I found out that frame-less windows (which I have) are very difficult to repair. The firm I mention above charges extra for frame-less windows and report that if a window breaks, it will take longer to repair if they don't have the right window pane.
Good luck if you do it and let us know how it comes out.
We've been to Suncoast several (5) times with varying results. The last time, the window came out fine with no issues, but earlier on they had some people there that really didn't care about their work, so we had to make the trip back a couple times. In an effort to find another solution when the door window started fogging, I called Lippert and gave them the original part number (label on the inside frame of the window. You have to remove it to see) and they made the exact replacement, and shipped it for less than the repair at Suncoast. I'm sure if Suncoast does the job correctly, it would last longer than the original replacement, but it's just another option.
