Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I don’t use it that way, but looking at the hardware devices from the Linux shell, it appears to be a single physical radio. I only use it for wan and use Ethernet to my dedicated access point.When using WiFi as WAN on the Peplink MAX BR1 mini I've found that my throughput is 1/2 of what I get when connecting directly to the home WiFi. As I understand it, this is because the BR1 is switch between connecting to the home wifi and being an AP. How does the Spitz AX perform where it is being used as both a Repeater and an AP? Does it have one or two WiFi modems?
@redbaron Are you using the starlink router to feed the GL-X3000 or using a power injector and feeding the starlink dishy direct to the GL-X3000 or ??I don’t use it that way, but looking at the hardware devices from the Linux shell, it appears to be a single physical radio. I only use it for wan and use Ethernet to my dedicated access point.
Hi - curious how the performance/speed compares to the Peplink (which model?) that you had previously?I am very happy with the Spitz. The performance is not the fastest, but it is very stable. It also handles the Wi-Fi as Wan and Starlink connections very well and is cheap enough that replacing it every 2-3 years with a newer model is feasible.
Another bonus, the built-in modem supports *magic* thru the UI. IYKYK
Not like Google is tracking me but this popped on my YouTube feed:
T-Mobile about 480Mbs, Starlink bursts of 600Mbs.Hi - curious how the performance/speed compares to the Peplink (which model?) that you had previously?
Thank you. That’s helpful.T-Mobile about 480Mbs, Starlink bursts of 600Mbs.
I had the peplink max br1 pro 5G
