Power door locks
MiniVistaCruiserJack
Hi everyone,
I noticed the power door locks doesn’t seem to be working on the passenger door side. The driver side still works. Any suggestions on how to troubleshoot this issue? Might be a loose connector somewhere? maybe a fuse needs replacing? I’m hoping not to have to remove the door panels… that’s major work 🤔
Pull the door panel and see if you can test the wiring. But you may need to replace the solenoid. The hardest part of this job is removing the door panel. Solenoid replacement is easy
Do you have a switch on the doors for the locks? If you do, do they work?
