Question Problem with Power cable storage in Liberty Coach 2014
Rejean Corbin
Is there someone who could tell me where can I access the power cable storage system in Prévost Liberty coach 2014, that I have to change the power supply cable in this Coach,
it seems to me in the center of the coach but I can't find the access, thank you for your help, Réjean
(I’m electromechanical)
I have a prevost marathon and I am not sure if all prevost chassis converters use the same setup. On a marathon, there is a drop door under the coach third bay door driver side from front. There a rocker switch on the panel to lower or close the drop door. I’d look around there as there may be a separate compartment that has the shore cord reel. You can also call Liberty support as well and they will direct you to exactly where it is.
