Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
12vdc on the blower.propane furnace blower (is this AC or DC? and how many amps does it draw? need to find out even though it's intermittent)
This is what I propose. Not only does my friend have his set up this way but I do, kind of. My solar and inverter/ battery bank is 24vdc and the inverter feeds the rv power cord. this handles all rv loads and charges and maintains the 12vdc battery and system native to the RV
A little about my set up. I use a refrigerator designed and built for apartment use, made by Avanti. I use a portable ice machine during the day. I use an Instant pot and inductive cook top. I have propane stove/oven and propane convective heater (not furnace). I have 1000w of my 2000w available solar. Seems that my almost identical solar controllers don't play together well, so I am waiting for another controller to get here.
With each RV I get I move my system from one to another as I store the unused RV. I have been using this type of set up for about 7 years with no problems. I have also set up such a system for at least 5 other RVers. Only difference between others system and mine is the choice to set up my solar as a 24 volt system, both systems work equally well, I just find adding a independent solar system simplifies the operation as only seldom do I need to plug into the grid and if I do I simply disconnect from inverter and connect to generator/grid.
One more note. I live off grid with my RV. Other than a 2 mo. stent while recovering this last year I could count the number of times I was on the grid sense 2003 on my fingers.
