redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Any 120v ac power. As long as the inverter has enough watts then you would be fine.Looks good, but what outlet in the trailer would I need to use ? Is this charger going to work plugged in on the inverter powered receptacles ?
The breaker for the circuit should be sized less than the inverter, so any 120v ac 15 amp outlet will be fine.
If you have 120v outlets less than 5 amps, avoid those.
