Recurve R3
I have this set up now on my RV and tow vehicle. My RV is in Aurora 24 RBS hitch weight 764 GVWR 7764 UVW 5619 CCC2145 From what I understand the bar is rated at 600 do I need to replace the bar or do I have to do the whole system to accommodate my new RV
I would use what I have! If I decide I needed different bars after a trip I would then replace them.
Welcome to RVforums from Ely, Iowa
If you set it up properly you will know immediately if it is okay or not. No need to take it for a ride. If you can't set it up to the parameters the manufacturer states then it will not be proper. Every truck, RV or trailer load requires a different setting, read the instructions that come with the hitch. And airbags and extra leafs are not proper. Good luck.
