Using 50 amp cord with #6 wire. No issues with any other electrical equipment on the rv.Sounds like either a poor connection on the 120 volt side or possibly a too small of a supply wire. Put the fridge on electric and start at the breaker panel with a digital voltage meter and check the voltage from one side and the other side of all connections at the same time. Any voltage showing on the meter will show the poor connection. When did this problem start?
Like I said, you need to look at the wiring in the RV. Start at the breaker panel in the RV and trace from there. There is a slim possibility that a staple pierced the wire gong to the fridge and it is finally showing up. The problem is in your RV.Using 50 amp cord with #6 wire. No issues with any other electrical equipment on the rv.
