Question Removing pressure from water line
Joe Dutchstar
Florida
Dutch Star 4311
Cummins
2018 Ford Flex
When we disconnect the water line, turn off spigot at campground then what to relieve pressure in the line?
Do I change setting from auto fill to manual fill??
That’s what I do, Joe.
Can also use an anti-siphon device right at the spigot. Turn off the water and it will auto drain the pressure.
Through the anti-siphon works, we use Neal's suggestion above, the splitter works great and easy to relieve the pressure with a quick flip of the wrist.
I use the hand shower in the wet bay.
Ditto on the Y connector. Plus I can put a hose on the other end to use for quick spray downs when needed.
I have two switch in the wet bay. One for the water pump and one to activate the tank fill. This is separate from the know to select bypass, city water, etc. I push the fill button which opens the valve to fill the tanks.l and releases the pressure.
