Replacement or repair of motor for leveling jacks on 2007 Newmar Canyon Star 3303
Pat O'Sullivan
This past fall, when trying to raise the LF leveling jack, the leg came up about 6 inches, squeeled and then stopped. In order to raise it all the way up I had to wedge a 2x4 under it and while the raise button was being pressed I used the 2x4 for leverage to force the leg up. I have an appointment with a local RV dealer and anticipate that it might be the motor that is not working. The other 3 legs raise and lower normally. Since parking it in October I have not tried to use the leveling legs yet. My inquiries indicate that the jacks are an Atwood product and no longer available from Newmar. I live in south central British Columbia, Canada.
Anyone have a similar issue and if so how was it solved?
Hmmm...I thought I responded to this yesterday but apparently I didn't hit send (post) 🤔 Lippert purchased the remaining Atwood inventory and has many (old) replacement parts for the Levelegs system. However, I don't believe they have motors. So, a secondary market of rebuilt motors exists. I'll try and find a source. Make sure it's not a controller issue. I had an issue and they did have the replacement for that. The controller pad is "sensitive" (as you probably already know) and I replaced that as well. Bottom line...If you can't find a motor replacement you can have it rebuilt. Blessings
Since 3 out of 4 of the jacks work, I would assume the motor isn't the problem. I would think the one jack is the issue. Probably just needs one jack replacement.
Our 2007 Bounder has a Power Gear electric leveling system. The right rear jack quit working last year and our mobile mechanic was able to get a replacement motor from Lippert, even after several shops said it was impossible because parts are no longer available...
A little critical thinking here. If the jack goes down, that means that the electric motor works. If 3 of the 4 go all the way up but the LF jack only goes up about 5 inches then stops, then the motor would seem to be working and something is holding it back. Could be dirty. I'm thinking maybe the whole jack needs to be removed, cleaned and re-lubricated and reinstalled. Any thoughts or experiences along those lines?
I took it into our local RV dealer (not a Newmar dealer) to get the roof inspected and the system ready for summer. They chewcked the level legs and they worked just fine. We used the motorhome this summer and never had a problem. It would appear that it might have been a chassis battery that was not holding enough charge after 3 legs went up which caused the 4th leg to stop. New battery installed and that seems to be the solution, Of course, we have not had the rig out in colder weather.
